Terrain - color interpolation/mask limitations
Hello! I'm using terrains a lot and i found a bit limiting being only able to use one color mask at once when interpolating different effects, as an example:
Imagine i have several features on my terrain: i have a road, some platforms and a couple hills. Some times i want my effects (blur, erosion...) to affect all of these at once, but sometimes i want one effect to specifically affect a single feature, without changing all the previous pipeline. Since i had to merge all masks on previous steps, it is impossible for me to get an isolated mask again
Right now the only solution would be keeping masks separate and create as many clones of the same effect as different masks i have, but this is truly inconvenient.
Something like a plus button in both, mask creation box and interpolation rollout would help a lot Big Grin so i could first create all my masks, then apply them at will on the effects i want when color-interpolating.
Thank you!
Hmm, to be honest I'm not entirely sure I understand what you're asking for...you want to be able to clone masks and merge them, while retaining the originals?
(02-04-2026, 02:54 PM)tyFlow Wrote: Hmm, to be honest I'm not entirely sure I understand what you're asking for...you want to be able to clone masks and merge them, while retaining the originals?
Hello! sorry if i did not explained myself too well. My main concern is not being able to apply more than one mask at a time. When i want to color interpolate, i can only choose one mask, and sometimes i need more than one mask.
The reason for all mesh masks not being merged into one or two masks is because i sometimes need terrain effects to affect only some parts of them.
Lets say have: mountain 1 mask, mountain 2 mask and river mask. I generated also 1 mask for each of them.
Then, i want to apply 3 different effects, one for each terrain part. That is fine since each one of these mountains/river got a different mask generated. But what happens when i want to apply another effect, but only to two of them or to all of them? I would have 2 or 3 identical effects, each one calling to a mask since i cannot use 2 different masks on a single effect.
Now i dont find a reason to my request of being able to generate more than one mask per Operator, lets forget about that part, since probably its the source of the confusion and now i cannot even remember why i asked for that. I hope the next image is more clear.
Thank you!
