tyactor animation blend
is it possible to have the blend option in Actor Animation to blend the existing animation/animations to be blended so it loops or smoothly play the next animation within the event.
for example, having multiple Idle animations that doesn't match at the startup/end frames.
for now, I can create the blend using two events I just thought it would be useful to have that option within just one.
Thanks!
You can just separate the clip names by commas in the same Actor Animation operator, and they'll be selected at random each time one finishes.
(02-06-2026, 02:50 PM)tyFlow Wrote: You can just separate the clip names by commas in the same Actor Animation operator, and they'll be selected at random each time one finishes.
sorry I didn't explain it well, but this is not what I mean, I am suggesting to 'Blend' the current animation with itself or with the listed animations frames in the same way how the 'blend' option works in the Animation operator with blending the previous animation.
thank you!
Oh I think I understand why it might not be working for you:
1) You need to ensure the Actor Animation timing is set to Continuous, if you want clips in the same event/operator to be blended/repeated together once they finish.
2) Currently this behavior only works when sequence selection is set to "shuffle".
If sequence selection is set to "Random", the only clip that will be played is a random one from the list (and it will only loop if you enable looping). And if sequence selection is set to "sequential", the clips will be blended, one after another, in order (up to the last one). "Shuffle" is the only mode that will continually reselect clips from the list (at random) and replay them (blended) if timing is set to Continuous.
Thanks! I have a better understanding of how it works now
it works very well with shuffle selected and loop switched off, to loop and cross fade the same animation with itself
working for multiple animations too
much appreciated!
