02-13-2026, 03:21 PM
(This post was last modified: 02-13-2026, 03:33 PM by Sputnikanimation.)
I have a VDB file that contains XYZ position and RGBA values of scanned science data. I want to import this into TYflow and create a particle system where each location is a particle of that color. So i end up with a cloud of multicolored particles based on the science data. In this case it's brain tissue from a stack of Tiff images. When I go to load in the VDB file it takes a while so it seems like it's doing something, but I can't see anything in the end result.
I'm using BirthVDB to import the VDB file.
When I look at the data channels there a 4 grids:
ChannelR
ChannelG
ChannelB
ChannelA
Do I need to combine the RGB into a single channel and use that for the UVW?
I've been looking all over but can't find a tutorial or forum thread that helps me understand this use case for VDBs.
I'm on a tight timeline to figure this out for this project so any assistance would be greatly appreaciated.
I can also get the data as X,Y,Z and color values as a text file - is there a way to ingest this into TY flow to create a particle of each color as each coordinate?
Thanks,
James
ChannelR
ChannelG
ChannelB
ChannelA
Thanks,
James
