Clean uninstall.
Question
Hello, folks.
A while ago I tried free version of tyFlow and had some problems with it - all tooltips were empty is the one I can recall at the moment and possible some other functionality was missing/broken. I suspect it might be caused by my experiments with tyDiffusion that I removed incorrectly.
That's why I'm looking for a way to completely and properly clean the system/max/registry of any and all tyX related entries. So I could do a clean install and be sure that's how it's supposed to work. Might need to use paid version and would like to avoid it malfunctioning due to bits and pieces of some older version scattered inside endless max folders.
You can remove tyDiffusion by deleting this folder:
C:\ProgramData\tyFlow\tyDiffusion
And removing tyFlow itself is as simple as deleting the .dlo from the Max plugins folder.
(02-17-2026, 04:09 PM)tyFlow Wrote: You can remove tyDiffusion by deleting this folder:
Thank you.
