Particles Pop Out of Existence In Render Not Viewport
So, I have a setup that makes particles fade in and fade out, so they don't just pop in and out of existence. And they appear to do just that in the viewport, however, in the render, it seems like some of the particles just pop out of existence toward the end of their life span, and I'm not sure why.
AMD Ryzen 9 5900X
Gigabyte RTX 3080 Gaming OC 12GB
1TB NVMe SSD, 2 x 1GB SATA SSD, 4TB external HDD
32 GB RAM
Windows 11 Pro
So, how you expect us to examine the case without sending max file, or even preview, or even max screenshot of the flow ?
It's case by case scenario.. you have some examples in official files (the one named with UVW).
Give me some more info, and I'll gladly help bro.
(03-02-2026, 11:06 PM)d4rk3lf Wrote: So, how you expect us  to examine the  case  without sending max file, or even preview, or even max screenshot of the flow ?
Here is the particles in the viewport as their scale fades out:
Here is the particles in the finished comp shot popping out of existence before they fully scale down to 0:
https://youtu.be/zUZgK4wk5fo
I've uploaded the Max file, ignore the missing texture, that's for the geosphere which has a star texture map applied. Need Max 2025 to open it.
.max   Nemesis Warp Stars.max (Size: 664 KB / Downloads: 143)
AMD Ryzen 9 5900X
32 GB RAM
Windows 11 Pro
One thing I did just notice is that they pop out of existence when viewing the particles with shading, but not when viewing as wireframe.
AMD Ryzen 9 5900X
32 GB RAM
Windows 11 Pro
(03-02-2026, 11:27 PM)Chrissonator Wrote: I've uploaded the Max file, ignore the missing texture, that's for the geosphere which has a star texture map applied. Need Max 2025 to open it.
Can you save it for Max 24... maybe even earlier?
Thanks.
Thanks.
2022 is the oldest I could save it.
.max   Nemesis Warp Stars 2022.max (Size: 664 KB / Downloads: 115)
AMD Ryzen 9 5900X
32 GB RAM
Windows 11 Pro
I think you need to have mesh operator in the second event too.
You need mesh operator in every event you want it to be rendered.
(03-04-2026, 12:13 PM)d4rk3lf Wrote: I think you need to have mesh operator in the second event too.
Okay, I'll give it a shot when I rerender the tyflow pass. Smile
AMD Ryzen 9 5900X
32 GB RAM
Windows 11 Pro
They still popped out of existence before completely scaling down to 0.
AMD Ryzen 9 5900X
32 GB RAM
Windows 11 Pro
