FumeFX
Hello It seams the FumeFX compatibility is not working .
am not able to transfer velocity or any data. nothing is showing up.
https://docs.afterworks.com/fumefx6max/F...0Fluid.htm
Which version of tyFlow are you using?
(03-05-2026, 06:58 PM)tyFlow Wrote: Which version of tyFlow are you using?
Hello
i downloaded the latest from here today and installed the latest FumeFX all today.
https://docs.tyflow.com/download/
tyflow 2.0
I can try to do whatever you suggest.
i just purchased fumefx just to open tyflow and see unlicensed tyflow.
is cool you make new features but it should be delivered separately. to bug fixes.
tyFlow v1.133
tyFlow v2.000
why so big jump in versioning like, there will be hot-fix version for users on pro ?
you say on facebook = FumeFX - v2.000 fixed some bugs related to interfacing with FumeFX so the functionality should be returned now.
so i have to buy new licence to get bugs?
there shoud be version prior to 2 that offers  bugs fixes.
You need to keep your key maintenance active to continue to get both bug fixes and new features, yes.
Can you clarify - the issue is happening in tyFlow v2.000 still? If so, please send your Max file where the problem is occurring. I tested FumeFX with v2.000 and didn’t detect any further issues.
(03-05-2026, 10:19 PM)tyFlow Wrote: You need to keep your key maintenance active to continue to get both bug fixes and new features, yes.
yes  tyFlow v2.000
it dos not see fumefx at all nothing
Post your Max file and I will test when I get a chance. Or send to [email protected]
(03-05-2026, 10:28 PM)tyFlow Wrote: Post your Max file and I will test when I get a chance. Or send to [email protected]
here if scene file
For a start you will need a startup file that can be downloaded from: https://bit.ly/3uPETZM
 In 3ds max, select File->Open, and then the file FluidForce_start.max
When I run the simulation of the "fluidforce_finish.max" file you posted I don't see anything actually simulated...so it seems more like a FumeFX bug or perhaps the file they created is outdated and requires different parameters to work in FFX 7 (does it simulate anything on your side?).
In a simpler FumeFX test of my own, particles are advected by the fluid without issue. I've attached the file for you to test on your side. Run the FumeFX simulation and then refresh the tyFlow simulation. This is running in tyFlow v2.000 and FFX 7.5.2.
.max   fumefx.max (Size: 676 KB / Downloads: 139)
(03-06-2026, 12:21 AM)tyFlow Wrote: When I run the simulation of the "fluidforce_finish.max" file you posted I don't see anything actually simulated...so it seems more like a FumeFX bug or perhaps the file they created is outdated and requires different parameters to work in FFX 7 (does it simulate anything on your side?).
Hello Thank you your file worked .
don't know what is the difference.
Please how do i do the same from ZENITH now that is in tyflow ?
i knead to get the particles to move from the smoke sim velocity  ?
the fluid force dos not work ?
Thank you
You can use an Inferno Properties operator to advect particles.
