03-06-2026, 10:58 PM
tyFlow v2.001 is up!
https://pro.tyflow.com
* added options to customize location to load CUDA modules from in tyFlow GPU rollout
* added new box size modes to tyIcon helper
* fixed an issue that could cause tyDiffusion to leak memory after opening, eventually filling up system RAM completely
* fixed an issue that could cause Max 2025 to crash during startup when VRay 6 is installed
* fixed an issue where 2XXX/3XXX GPUs would not run Inferno simulations
* Inferno Recall operator will now warn users if their GPU is not compatible with compression requirement (compute capability 7.0+ required)
* fixed an issue where Inferno Recall operator was not showing warning if required DLLs not found
* added checkbox option to not display C++ redistributable version warning again, if a problem version is detected on your machine
* fixed an issue where the tyMaterial modifier would always generate a multi-sub material with at least 100 submaterials, regardless of what the specific max unique ID range was
* Inferno Emitter operator can now emit negative temperature values
* fixed an issue where the Inferno Export operator wouldn't export temperature in some situations
* fixed some editor drawing issues related to windows DPI scaling
* fixed a regression where VRay render/IPR could crash in certain versions of Max when multiple versions of VRay exist on the machine
* fixed an issue where Inferno velocity streamlines would not be displayed for active solver frames
* improved behavior of middle-click spinner value stepper popup
* fixed an issue that could cause the Export Inferno operator to crash when exporting an upres'd sim
