Split mesh element in shape operator messing up
Hi!
When I apply pre-face fractured mesh into shape operator and enable split mesh elements, it messes particle location, even though they are not center pivot. I tried doing it with groups also, same result.
I am uploading two images
one with enable split mesh element and another without it.
Can you recommend any solution, as I am in the middle of the project and I dont have any other solution for instancing right now.
Thank you
Nayan Bodawala
Can't guess without a file.
Try Repair op > reset xforms.
(03-14-2026, 09:35 PM)tyFlow Wrote: Can't guess without a file.
Here's the file, I tried with simple Geosphere, its still getting the same issue....
Please look into this
Thank you
Nayan Bodawala
.max   ShapeOperatorIssue_2026.max (Size: 808 KB / Downloads: 124)
Hi!
Can you please check.
Thank you
Nayan Bodawala
This is just how the Shape operator works. Mesh elements are randomly selected for particles, not assigned in order. You see missing pieces because those pieces weren't assigned during the random selection process. If you need all elements assigned as particles, use Birth Objects instead.
So here's my situation, I am scattering 8 varieties of flowers on 10k particles, and through neighbor count each flower is disintegrating. What I am doing is when the neighbor is true, I spawn the pre-fractured version of that flower through ShapeID, how I spawn is I spawn offspring equal to the number of prefractured elements in the model and then shrough shape operator I split the elements and as I haven't changed the pivot, I should get exactly where they are. This way all my instances are maintained and memory footprint is very very low. I tried with face fracture operator or element operator but in both case I loose instancing and my memory without cache crosses 128GB due to mesh.
So in this scenario I cannot use Birth Object Operator. If you have any solution please let me know, and is there a possibility to have a ordered split element option in shape operator - it can be very useful.
Thank you
Nayan Bodawala
Use Birth Objects in one flow, then add that flow to a tyActor and scatter using actors in another. Instances should be preserved. Disable actor animation in the second flow so you can move the pieces freely.
Yeah, thank you
I tried using tyActor, works absolutely fine, but it becomes incredibly slow compared to shape operator.
