tyFlow v2.003
tyFlow v2.003 is up!
https://pro.tyflow.com
* added flipbook image export to the Export Inferno operator
* added option to emit only above or only below triangles in Inferno Emitter operator
* added options to push emission mesh vertices in/out in Inferno Emitter meshes rollout
* added option to mask velocity with density in Export Inferno operator - reduces file size by skipping velocity voxels that have no density
* fixed an issue where tyFlow Inferno sims would reset when starting a tyPreview or changing the scene timeline start/end frame, if a camera was added to an Inferno Bounds operator
* fixed a crash that could occur during Inferno VDB cache export
* fixed an issue where fast emission mode wasn't being applied to thickness overrides in the Inferno Emitter operator
* fixed an issue where Force operator aerodynamic forces were not applying to tyWind forces
* fixed an issue where mapping overrides applied to cloth particles would sometimes not transfer to cloth meshes properly
* fixed an issue where vertex velocities written to a mesh by a tyVertexVelocity modifier could not be read properly by an Inferno Emitter operator when velocities from map channel was enabled
* fixed an issue where zero-volume meshes could crash when Inferno Emitter set to volume emission
* fixed an issue where Inferno Display would show nothing in the viewport when recalling cached frames that only contain fuel data
* fixed an issue where clicking the [>] button on MAXScript operators could trigger an operator drag operation
* fixed an issue where distance affect limiters of tyWind forces were not affecting Inferno wind noise calculations
(03-16-2026, 02:23 PM)dv2000 Wrote: Why am I getting these  errors?  Do I need the latest  Microsoft Visual C++ Redistributable?
Bro, Isn't it says exactly in the warning message what you need to do?
I had the same, installed it.. and it never popped out again.
Btw I never tried upres yet...
I saw on faceboook group this... same issue as you (grayed out upres), and this is the guy's answer:
