04-20-2026, 11:41 PM
G'Day
So, this is a bit of a technical look at 'Sticky Starting Penetrations' and the trouble with it and that you can get serious particle penetrations using it without checking for penetrations.
Everything you need to do in PhysX can be done with 'Process All Penetrations' - That's not to say you shouldn't use the Sticky Mode, that's up to you!
If you want to learn how to manage and control penetrations, then this is the video for you
Rob
Link:
https://youtu.be/mblSU8swV_w
Rob
Link:
