hello, I suggest assigning one to each of the two operators.
First, regarding the Particle Bind operator: the “bind to parent” option currently includes “only if first child.” Wouldn’t it be useful to add a “only if last child” option as well?
The advantage of this is that when spawning moving particles using “by travel distance” and connecting them into a single line, it would become easier to ensure the line remains unbroken.
Another suggestion is to add a “reset particle age” option to the Resample operator, similar to the Spawn operator.
For example, when binding particles generated by a “birth spline” and trying to spread them out like a wave, if you want to animate the line thickness from thick to thin based on “particle age” or “event age,” using resampling for interpolation causes the line thickness to not animate uniformly.
What do you think? Thank you for your consideration.
Masa
Masa
