Previewing Clusters
Is there not a way to preview cluster colors on the particle shape in the viewport? It seems to work only on the particle ticks, which is harder to see.
thx
The closest workaround would be to assign your clusters to material IDs (using the Material ID operator), then assign a multi/sub material with different colors for each ID to your particle system. You can generate a randomized multi/sub material like that from the editor > right-click > utilities menu.
Thanks that works
