Path follow logic
Hello, I often use Tyflow to make particles move along a path.
Every time, I have the problem that the particles spiral around the path, even though spin is completely turned off. Or the particles behave like beads on a string and jiggle.
I just don't understand the logic behind the settings. If I compare it to PhoenixFD, where you can set speed along a path, how far the particles can stray from the path, and how fast they can rotate around it, that would be much more user-friendly than all these settings that seem to cancel each other out.
Unfortunately, the documentation isn't helpful either, and tutorials usually only work if you set up the exact same configuration.
Does anyone know of a resource where these many settings are explained in a practical way?
Can you give a concrete example of a scene in which you're having path issues?
