05-12-2026, 08:36 PM
tyFlow v2.009 is up!
https://pro.tyflow.com
* all Inferno operator documentation is now online (https://docs.tyflow.com/tyflow_operators/inferno/)
* added new spline bind mode to PhysX Bind operator
* custom string filters can now take multiple strings, split with commas (ex: a search string of "node001, node002" will return a value based on whether either substring has a match)
* added material conservation option to Birth Inferno operator, for properly conserving the total mass of density/temperature/fuel in turbulent domains over time
* Export Particles, Export Terrain, Export Inferno and Export VDB operators renamed to Particle Export, Terrain Export, Inferno Export and VDB Export, respectively
* increased maximum quality/resolution of color output in tyTerrain Downloader - also fixed issue where "current zoom level" would sometimes return higher quality results than "highest quality" setting
* tyTerrain Downloader will now download height/color data in parallel, instead of sequentially - downloads can also be cancelled
* fixed an issue where the Inferno Scale operator's bake operation would not affect Inferno operators in events connected by Inferno Connect operators
* Inferno Export VDBs now downsaved to v223, for OpenVDB v11+ compatibility
