Hello! Im struggling to export my nodes. Its a simple task but Im begginer on Tyflow. I just cant export to Tycache this set. On the attached files Ive sent my set of nodes, how the tyflow is doing (which is fine I just need to export) and how the tycache is exporting. If somebody have an idea Id appreciate a lot. Thanks
When I try to export the purple and yellow particles the tycache comes as the green one. The tyflow is runnin fine but just cant export the whole thing, looks like he is exporting part of the nodes only.
Then just put the Export operator in the event you want to export particles from. When it's in its own event, it will export all particles. If you need to export from multiple events, you can instance the Export operator across them (SHIFT + ALT + drag to copy as instance).
