06-24-2026, 05:00 AM
Hello, I have Question.
I recall that in the past, when generating a VDB using “Particle to SDF,” I was able to change the VDB’s color to match the particle’s color changes using the “Particle UVW” option in “VDB Modify,” but it seems that this is no longer possible in the current version 2010.
Has the procedure changed in any way?
Tyson Ibele, Thank you in advance. masa
