07-22-2026, 06:15 PM
3ds Max 2027.2 is a huge update, implementing a new point/point instance class.
Would be amazing to implement a direct support in tyflow.
-First implementation could be just load points and instances. We can in 3dsmax array objects as points, and create instances, Its a single object. If tyflow supports points, we could load this single object, and tyflow will recognize positions, transforms and mesh instances. Loading heavy instanced meshes will be way faster, we will get all the transforms, etc....
-Will be great a way to output tyflow as a point/point instance data. The solution could be in different forms, convert a tycache to points? or a live modifier on top a tyflow that does this on the fly?
