Retiming Inferno to VDB?
So I've got an inferno sim.  I exported it as VDB.  Then I load it as a Recall - VDB File.  Then I retime it and enable interpolation etc.
All good! Everything works great.... in the viewport.  But how do I export the retimed sim to VDB? It looks like I just get a static single frame over and over outputted not the new retimed/resimmed version.
You've set the Inferno Export operator to export from the recall cache?
(09-12-2026, 03:33 AM)tyFlow Wrote: You've set the Inferno Export operator to export from the recall cache?
Don't I need to set it to "Solver" for the export source since the Inferno Recall has the retime and rescale parameters?
If you're retiming, which happens in the Recall operator, then you need to export from the Recall cache in order to export that retimed result.
