tyVehicle: Wheel Breaks
What would be the easiest way to add break-meshes to the wheels?
I can think of a few - mostly complicated - solutions, but guess there must be an easy approach?
Simply linking the break meshes to the wheel meshes doesn't work of course: the breaks should not rotate with the wheel-axis rotation.
Thanks!
Create a strut helper from your tyVehicle helper's create menu - set both the base and end helpers of the strut to the wheel. Now it will follow the wheel suspension/steering, but not the spin. Then link your brake to the strut.
Works like a charm, thanks for the quick reply!
