Creating particles onto dipped object surface
I need to create particles onto surface by dipping an object into a pool. So I have this object that travels through a pool and when it's lifted off the pool, it should be covered with particles.
I have used quite a few approaches so far, but I'm not pleased yet. The pool itself should not contain any particles, it's a Chaos Phoenix simulation. It works fine in the pool, but not in the dipped objects, so I decided to try that part with tyFlow. Also not all of the dipped object should be covered, only selected surfaces (there's a suction in real life, that makes the liquid stick to surface).
I can get the sticky effect in Phoenix, but after that it get's tricky. Liquid turns into more or less to solid and it's scraped of the object's surface. That's the point where I gave up with Phoenix and decided to split this: filled pool - Phoenix and sticky, solid substance - tyFlow.
Mi goal is to create similar action than in sample scene tyFlow Fracture (the Torus Knot thing). Instead of moving deflector I move somewhat solid particle cake. Through the deflector where the particle cake is transformed into chunks.
The cake if formed in a pool onto a cylindrical surface.
OK,
I got now particles moving with the sticky surface somewhat correctly. Now I need to make particles continuous surface in this event and fracture it for the next event. What do I need to do?
So, what would be the correct procedure to break the binding on cylinder and let particle be scraped of the surface?
[Image: attachment.php?aid=4660]
So tyFlow seems to break the bind now, but how can I apply the Physics after and send the particles to next event?
I think I managed to break the bind. The Max force had to be as low as 5.0mm.
Next step would be breaking the tyMesh after the bind is broken. I would like break it into chunks, that fall freely.
[Image: attachment.php?aid=4664]
I decided to send particles into a new event. It leaves the initial event correctly, but ignores collision objects in new event.
[Image: attachment.php?aid=4666]
I reduced the operators to minimum without any change in output. Particles depart from Event 1 but don't react after that with any operator. Particles continue to move the direction they were moving the moment they leave Event 1. I cannot control particles after that.
[Image: attachment.php?aid=4667]
I think it's working now.
[Image: attachment.php?aid=4668]
Now I got a new problem. I got the tyMesh now correctly in my render scene. However V-Ray crashes during rendering.
I rebooted the workstation and now it seems to be rendering fine.
Rebooting is underrated method for problem solving.
It's getting better, but there's still lot to do. I'm using tyMesher toe create a solid mesh over the particles. One final step would be to fracture the mesh into chunks when it's scaped of the cylinder surface. I would describe the substance candle wax like. What would be the correct procedure for that?
I tried to use this tyMesh into fresh tyFlow like in the Torus Knot fracture sample file, but Max crashes. Maybe this tyMesh is too complex.
[Image: attachment.php?aid=4677]
I think, this is the result, I want to achieve, but I haven't been able to get it with tyMesh. On the sample file it works fine with Max primitives, but not with the geometry I have in my animation.
[Image: attachment.php?aid=4678]
The difference to this sample above is, that I want to have the deflector stationary and move the objects to be fractured instead.
When I disable the deflector animation and animate the torusknot geometry to travel through the deflector, nothing happens. Is there anything, I should try differently?
I continue my monologue. I gave up using tyMesher particles on this and decided to do geometry instead to make the chunks. Here's two sources: one animated tube segment and one animated box. The box is fractures, but the tube segment does nothing.
[Image: attachment.php?aid=4681]
I wonder what's collision is doing. I see some problems here. There's two source objects: one for reference and one for real. Both objects react collider (see the color change). However only the reference object is breaking in the new event, but the needed real object don't show any physics behavior. I don't see any reason why it shouldn't work like the reference object.
The other problem is, that the reference object disintegrates correctly, but it also explodes when moves to new event. Why doesn't it follow Physics?
[Image: attachment.php?aid=4683]
So I changed my approach. I think, it should be fine if I get the fragments created with tyMultifracture modifier detached from the "cake". I have here the chunks, that I want to scrape of the drum. Later they will be crushed to smaller chunks, but now I want to get control to the chunks.
[Image: attachment.php?aid=4684]
So this is the point, where I am after working a month (including weekends) with the project. Good thing is, I have the fragments ready, but I cannot control the fragments.
[Image: attachment.php?aid=4686]
After spending weeks after weeks with Copilot on this, the conclusion was, the problem is tyFlow limitations. If someone can confirm this, we can start searching workarounds.
So basically the idea was that I have previously fragmented object. Fragments are detached one by one when they reach the scraper. However when I try this, the system explodes all over the place. Until that point everything looks excellent.
At this point the workaround would be, I detached all 500 fragments to individual objects (for starters). and then add these particles one by one into tyFlow.
[Image: attachment.php?aid=4687]
I don't know if this step forward or backwards. Anyway we have now the prepared fragments converted into single objects and imported to tyFlow as shapes, Now I need to get the orientation right. The particles (brownish) should start using physics as they touch the yellowish plane. The particles shapes are rotating along the dummy. Now I need to know why the particles are missplaced.
[Image: attachment.php?aid=4688]
If there were a place where I could ask questions about tyFlow, I would ask why the particles are being born like they are born on the attached screenshot.
Then my bonus question would be why there are holes - like not every particles are counted in.
[Image: attachment.php?aid=4689]
I just want to place the tyFragments to the selected faces of this cylinder, What is it that I'm missing?
[Image: attachment.php?aid=4690]
Haven't found yet a way to place particles correctly onto the cylinder surface. It looks like particles are correctly placed, but their orientation is total mess. Any ideas?
We see that particles are correctly transferred to event_002 (Color changes). They even collide correctly.
[Image: attachment.php?aid=4691]
I got the orientation right, if I link them to animated parent. However this isn't the final solution, because I need to break the link somehow at the marked spot. Now they don't leave the initial first event. I don't have any other active operators ran birth and collision. The later should send the particles to next event after they are scarped of the drum.
[Image: attachment.php?aid=4692]
I think, I have solution for first stage. The fragments would slide down to a screw conveyor. There will be need for further fragmentation.
[Image: attachment.php?aid=4693]
