tyFlow v0.16020 (BETA)
New version is out!
http://beta.tyflow.com
* you can now change the dispaly wirecolor of tyFlow object icons
* listbox [...] menus now have hide/unhide options
* Spin operator now has interpolation setting
* Particle Force can now use the flow's own particles
* Export Particles will now respect tyFlow retimer settings (an additional option has been added to ignore retimer settings)
* added the ability to query the particles of any event in the flow, by event name, in the Script operator (see API for "GetEventParticles(name)" function)
* fixed a bug where Voronoi Fracture points derived from an external flow were positioned using the wrong coordinate system (therefore offset from target particles).
* fixed a bug where Rotation operator interpolation variation was not being computed correctly
* fixed an issue where small simulation time steps could cause the PhysX sleep settings to activate prematurely
* fixed an issue where tyCache would keep evaluating forever if retiming (by speed) was enabled on the flow
* fixed a bug where Particle Force was not resetting properly, resulting in incorrect behavior upon resimulation
* fixed a bug where the Rasterize operator "Delete if overlapping" option was not working properly
