"Spread"Node_turbulence
"Spread", can you add a turbulence? Although there is now a "noise spread", the effect is not comparable to the turbulent form. I hope to improve "noise spread"
Although it is possible to pass the force field to achieve the effect of turbulence, or the wind field. But what I want is to change the shape in the first frame, without adding additional force fields to reach
