05-10-2019, 09:07 AM
tyFlow v0.16021 is out!
http://beta.tyflow.com
* fixed an issue where Particle Force would crash if no particle groups were assigned in the flow
* fixed an issue where a voronoi cloud point at the origin (0,0,0) would be created when using a source flow as the cloud source
* fixed an issue where the Material ID operator would crash if set to get IDs from a surface with zero faces
* fixed an issue that could cause scenes containing tyCaches to crash on reset
* fixed a bug where the "$(tyFlowLayer)" layer keyword was not working in the tyCache exporter
* fixed bug where Scale operator "relative add" was not working when time steps were smaller than 1 frame
