tyFlow v0.16023 (BETA)
New version is out!
http://beta.tyflow.com
Additons:
* added Integrate operator for immediately integrating particle velocities into particle positions, instead of at the end of the time step
* Resample operator can now send out created particles
* right click menu options to batch export all particles set to export with Export Particles operators
* Birth Fluid operator given new channel threshold overrides, for more precise control over which cells will birth new particles
* added 'parent deleted' property test
* added button to center the tyFlow editor window over the max window in the tyFlow main rollout
* added a "Max dist" setting for tySplines in sibling mode, so you can control the maximum distance allowed between sibling particles in order for them to become conjoined with a spline
* added 'face center' location for Position Object
* added more force influence options to Point Force operator (radius by shape/scale)
* fixed a bug where max would crash if a tyCache object was added to a VRay light include/exclude list
* fixed a bug where particles spawned from deconverted cloth could not be converted back into cloth
* fixed a bug where VRayMetaballs was not rendering tyCache particles at the proper scale
* fixed an issue where Script operators with errors would terminate a network render task even if they are disabled or not used in the flow
* fixed an issue with the Find Target operator producing strange/buggy results in some circumstances
* fixed a rare corner case where tyFlow would continually recalculate the simulation if the retimer was enabled and the active time was at a subframe not included in the cache
* fixed an issue where particle sleeping could cause jittering in cloth, especially when applying cloth inflation
* fixed an issue where enabling "weld bindings" in a tySplines object could scramble the direction of UV coordinates on each subspline
* fixed a bug where certain Object Bind controls were not updating their UI properly
(05-23-2019, 08:16 AM)tyFlow Wrote: * added 'face center' location for Position Object
coolcoolcool
