tyFlow v0.16024 (BETA)
New version is out!
http://beta.tyflow.com
* menus have been added to all custom data channel text boxes to allow quick selection of existing channel names for each data type
* Particle Force operator can now use particle shape/scale as influence radii
* Added tyWind helper that has more advanced falloff parameters than built-in wind spacewarps
* fixed an issue that was causing simulation indeterminism when using input objects with more than 10k vertices
* fixed a bug where multiple references to the same input node within a tyActor setup would result in multiple particles being generated for the same node within tyFlow
* fixed a bug that caused a crash when assigning a material override to an entry within the Shape operator
* fixed an issue where Time Test values were not animatable
* fixed a bug where deactivated particles would still fall asleep
