delete cloth shapes
i have a Little Problem.
when i trying to delete particle that have a Cloth bind solver they loose there shape (like exploding) before they are deleted. trying to convert them back with a Cloth bind (de-convert) does not help.
Any ideas ? or is this a bug ?
Regards H.Kroeber
I found out that the Cloth particles loose shape if there is no particle in the first Event anymore…
Here is a testscene
Regards
H.Kroeber
.max   Test4Tyson.max (Size: 2.95 MB / Downloads: 570)
Took me forever to figure this one out, but it will be finally fixed in v0.16027.
(06-06-2019, 05:52 AM)tyFlow Wrote: Took me forever to figure this one out, but it will be finally fixed in v0.16027.
Thanks..
i was not sure if i am blind not seeing what i do wrong so i did a lot of Tests. in the attached file (in this post )here i got another issue that from Frame 775 on the particles wont be converted to Cloth anymore.. is this bug fixed too ?
Regards
H.Kroeber
.max   test2_4tyson.max (Size: 2.47 MB / Downloads: 604)
Thanks..
Regards
H.Kroeber
this bug isnt fixed.. ;-(
Thanks..
Regards
H.Kroeber
That is a separate issue that should be fixed in v0.16028.
(06-06-2019, 07:15 PM)tyFlow Wrote: That is a separate issue that should be fixed in v0.16028.
Thanks …
you saved my day ;-)
