mapping...
So i have a stripped torus knot that i am sourcing mapping from and it works in the viewport.  However after rendering the mapping is all messed up.
Any ideas why?  (mapping is set to continuous as i thought birth was locking the texture in, even if it passes over stripes).
Here's a grab:
https://www.dropbox.com/s/lyv1qvgd1zikws...6.png?dl=0
Could be a bug, can you provide the scene file?
(06-10-2019, 08:16 PM)tyFlow Wrote: Could be a bug, can you provide the scene file?
Sure, here it is.
I think you forgot the attachment Smile (remember to click 'add attachment' after choosing it)
(06-11-2019, 02:47 PM)tyFlow Wrote: I think you forgot the attachment Smile (remember to click 'add attachment' after choosing it)
Sure did!
.max   branchFrost_007.max (Size: 904 KB / Downloads: 370)
It's not a tyFlow bug. The error is caused by your Checker map.
You have the x axis set to "Mirror" and tiling to ".01" which is causing filtering issues. Maps are not filtered in the view in the same way, which is why it's not visible.
AH i am not so smart.
thanks.
