tyFlow v0.16030 (BETA)
tyFlow v0.16030 is up!
http://beta.tyflow.com
* added tabs at top of tyFlow UI that allow you to easily switch between flow editors
* added a Camera Cull operator for culling occluded particles from display/render
* all single-node pickbuttons now have a dropdown menu for selecting or removing the picked node
* tyActors now support mesh deformations on non-skinned input meshes
* the tyCache exporter will now include particle render instance material overrides in tyCache files
* tyActor mesh deformations will now interpolate properly when simulation is slowed down with the retimer
* fixed a crash that could occur when rendering particles using VRay instancing
* fixed a bug where "Update in render only" for animated shapes in the Shape operator was not working for static flows
* fixed bugs related to the particle interface that was causing it to return velocities of improper scale in some circumstances (this bug was preventing particle velocities from properly influence FumeFX simulations, for example)
Quote:* added tabs at top of tyFlow UI that allow you to easily switch between flow editors
These are the two best updates everĀ  Heart
