Can not animate spread operator values
Hi all -
I have a super simple event with
-birth shape (geometry)
-Voroni Fracture
-Mesh
-Spread
-display
I cant animate the spread. In fact, when I hit auto key, changing the spread values does nothing. If I turn off auto key then spread acts as expected (spreading apart the Voroni Fracture pieces).
Am I missing something, or is this a bug?
Thanks.
Sam
Are you saying keys cannot be set on the spinners? Or that you don't see change over time? Did you set the Spread operator timing to continuous?
(06-27-2019, 12:38 AM)tyFlow Wrote: Are you saying keys cannot be set on the spinners? Or that you don't see change over time? Did you set the Spread operator timing to continuous?
That was it, I did not have timing set to continuous.
Thanks so much!
