07-09-2019, 04:02 AM
tyFlow v0.16037 is out!
http://beta.tyflow.com
* alembic mesh export support added to Export Particles operator
* tyConform modifier supports conforming splines
* Object Bind, Find Target and Modify Bindings operators have all been given timing/filter rollouts
* added sort and randomize options to listbox [...] menus
* added "add selected" button to all relevant helpers, objects and modifiers (use max's "pin stack" feature to add a new selection to a helper/object/modifiers node listbox)
* added value multiplier for float/vector channels of Custom Properties operator
* cleaned up Modify Bindings operator UI and added "multiply original" operation.
* deconverted cloth particles will inherit the properties of their source cloth driver particles (inherits from the first particle of the driver array)
* Property Test operator can now test texmaps using particle mapping coordinates
* Added option in tyCache exporter to only create tyCache node if existing node for the sequence is not already in the scene, otherwise the existing node will simply have its internal cache updated/cleared.
* fixed a typo where export group button labels were sometimes out of order
* fixed a bug where groups instanced by the Shape/Birth Shape operator were not retaining their UVW coordinates
* fixed crash that could occur when using tyConform on a spline with UV conform enabled
