Export problem & Boolean problem
when I tried to export particles into MESH, the number of particles was more than 1000, and the system interface was locked after pressing the output button.
After the stack uses two Boolean modifiers, the object animation process fails
MAX 2019
.max   BUGA.max (Size: 632 KB / Downloads: 353)
.max   BUGB.max (Size: 780 KB / Downloads: 330)
I'm not sure what you mean by the boolean comment, but the Export Particles problem has already been fixed and the fix will appear in the next release Smile
(07-13-2019, 12:57 AM)tyFlow Wrote: I'm not sure what you mean by the boolean comment, but the Export Particles problem has already been fixed and the fix will appear in the next release Smile
HI TY, I have updated two files. please download and check them. thank you very much.
Thanks for the scene files, these issues should be fixed in the next version.
