tySplines - radial variation
Would be great if tySplines could have variation on the thickness and angle etc
Thanks,
M
You can already do this, just choose the option to inherit knot radius from particles, and set variation on your particles.
Because internally there is no notion of "subspline ID" in a spline object, it's not viable to add the variation within the mesher itself, since if subspline count changes that will affect the random seed of each subspline and cause jittering in the mesher if per-subspline variation is applied.
Thanks Tyson, makes sense!
