tymesher not working with retimed tycache
Hey Tyson,
Not sure if this is a bug, or if there is a proper way to make this work.....but I'm using a tycache with the re-timer function to get a slow motion effect for part of the simulation.  When I use a tymesher on the simulation, it does not calculate any of the re-timed subframes.  No re-timer, meshes perfectly on every frame....with the re-timer, it studders throughout the playback.  I built the scene in Version 37....I updated to the latest 39, and it still happens.
I've attached 3 files.....
- In "*_a" you'll see that the tycache is playing back perfect on every frame with the re-timer enabled.
- In "*_b" you'll see that the tymesher only calculates every 7 or 8 frames
- In "* 2" you can see the random studder as it plays back with re-timer enabled
I'm working in MAX 2018 with NO V-Ray
Please advise on how to fix this, or let me know if it's a bug and I'll hold off on my rendering.
THANK YOU!
-chris
.mp4   Slowmo tymesher not working 2.mp4 (Size: 2.7 MB / Downloads: 326)
.mp4   Slowmo tymesher not working_a.mp4 (Size: 4.08 MB / Downloads: 330)
.mp4   Slowmo tymesher not working_b.mp4 (Size: 1.41 MB / Downloads: 333)
Hey, this is a bug and I will try to get it fixed up for the next version.
(07-23-2019, 03:45 AM)tyFlow Wrote: Hey, this is a bug and I will try to get it fixed up for the next version.
Thank you so much for the quick response....Good to know, I look forward to future updates!
