07-23-2019, 07:26 AM
tyFlow v0.16040 is up!
http://beta.tyflow.com
* added a "%" spinner to Particle Bind operator controlling the percentage of bindings that the break settings will apply to (bindings outside of this percent will not be breakable).
* due to bugs in max's Alembic implementation (causing repeated rogue change notifications in some situations each time the viewport refreshes, which causes tyFlow to continually reset the simulation), ALL Alembic notifications are now ignored when "ignore .abc notifications" is enabled in the Debugging rollout (and it is enabled by default), rather than just those sent when the time slider moves.
* fixed a regression where non-instanced meshes would not carry over mapping overrides
* fixed an issue where Property Test was returning the wrong matID values to test (note: if you were previously using a Property Test to test for Material IDs, increase your test value by 1 to be compatible with this change! So if your test value was 3, change it to 4, etc.)
* fixed a crash that could occur during Voronoi fracture if the input mesh has no faces
* fixed a bug where tyMesher would sometimes not update properly
* fixed a bug where Particle Bind "break max length" was not having the proper effect
* fixed an issue with Particle Bind display showing binds as black instead of the operator color, or were not showing until a sim refresh
