Hello guys, hello Thyson,
thanks for Tyflow, first of all, it´s amazing!
I have a quick question concerning TySplines. Is there a way to convert them into a normal mesh or poly object? The reason why I want to do this is, that I only need a single still image and the tysplines look too "messy" to use, so I wanted to remove parts of it manually.
If I convert the TySplines to editable splines, editable mesh or poly, the whole geometry just disappears.
Thanks in advance!
Dennis
Oh I think I solved it myself.
I had to put the Mesh operator to mesh (triangles) instead of vray instances. I also needed to apply a mesh select modifier on top.
Now it works
Thanks in advance!
Dennis
Now it works
