tyCache Render Crash
Hey
Reporting a crash I had.... in 3DS 2020 with VRay 3.7
After creating a tyCache with the particle export; when trying to render (in the same scene as it was created) it crashes 3DS once the lighting loads.
However, it works fine in a fresh scene with a newly created tyCache and link to the cache files.
I was using VRay, didn't test with scanline. Might try it later if I get a chance just to check.
I've attached the file.
Cheers
.max   AttractionTest.max (Size: 1.46 MB / Downloads: 235)
Thanks for the file, I can repro the issue here but the minidump reports the problem being inside VRay and doesn't report any relevant issue about which parts of tyFlow are causing it, so I'll pass it along the ChaosGroup and see if they can help to track it down.
