Please add "Close spline" function to tySpline Object
I think it would be great if you can add a simple "Close spline" funtion to the tySpline Object.
Then it will be possible to use the cap functions of the standard 3dsmax "Extrude" modifier with tySplines. I'm pretty shure that you can achieve some nice effects this way.
3dsmax standard "Normalize Spline 2" modifier has the option for close a spline (checkbox), but it returns a script error and will not work when I apply it to a tySpline.
Thanks.
Did you try to weld options? It should close any existing loops.
Yes I tried. It doesn't work. I sent you an email in reference to this thread with the max file attached. But maybe I did something wrong.
