Object bind operator: Per axis selection - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Feature Requests (https://forum.tyflow.com/forum-4.html) +--- Thread: Object bind operator: Per axis selection (/thread-1802.html) |
Object bind operator: Per axis selection - TubeSmokeGuy - 06-29-2020 Hi! Can you please add per axis selections to object bind operator for P|R|S to define which axes should be affected? F.e. when I enable rotation bind and I want that the particle is locked to the objects "Z" rotation only, so that just its X and Y rotations can further be affected by other effects. Maybe a switch if the axis binding should be Local-to-Local, World-to-World or World-to-Local would be good too in this case. Would be great!
