tyFlow v0.16042 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16042 (BETA) (/thread-939.html) |
tyFlow v0.16042 (BETA) - tyFlow - 07-25-2019 tyFlow v0.16042 is out! http://beta.tyflow.com Additions: * added render index override for tySwitchers * DeleteParticle function added to script operator * Export Particles operator supports typed-in relative paths Fixes: * Shape operator now compatible with tySwitcher, tyCollection (although it can only use the first member of a tyCollection array) * fixed a regression affecting VRay instance voxel bbox size calculations, which could result in a VRay render error * fixed an issue where unescaped special characters in the vrmesh exporter output path would prevent the export from completing properly. * improved Bind Solver sim stability when a large disparity exists between various particle radii RE: tyFlow v0.16042 (BETA) - smad - 12-19-2019 Hey Tyson, I would like to load long list of objects in a specific order; the TYcollection is made for that? if I understood, but it does not work in the shape operator? (it is not possible to put it in the shape operator, or I didn't understand how to use it.) Thank you in advance . and thank you for your great tool. |
