EXPORT tymesher to maya
Hello i tryed to export my tymesher composed of 4 animated polygons (no particles) but nothing works.
My alembic (in maya) doesn't play the animation.
Did i need to make something more before export ?  Huh
thanks
Ok i find a solution, by putting an edit poly on top of my tymesher, alembic now exports the animation.
Take care the file is bigger !!
(06-24-2020, 07:36 AM)konarovic Wrote: Hello i tryed to export my tymesher composed of 4 animated polygons (no particles) but nothing works.
thanks
thanks a lot, was  facing same issue , your solution helped
I was searching for a way to export ABC from tyMesher, and I found your post, but when I apply and Edit Poly modifier on top of TyMesher everything disappear.
Can you please provide some more info about the correct procedure?
I'm trying to export a tyMeshed particle animation to an ABC sequence without any luck so far.
Thank you
