Spline Paths operator not creating splines in physx bindings mode
Hi Tyson, I am having an issue when I enable the "collider" checkbox in proximity bind in physx bind operator the spline paths op does not generate the splines.
the bind is visible when I check show bindings but it does not generate the splines. Attaching a file please look into it.
Thanks.
.max   test.max (Size: 648 KB / Downloads: 330)
Hi Apratim,
The Spline Paths operator creates splines between particles, hence it not creating a spline between a particle and a collider.
If you need the bind visible in your setup, you can create a hidden particle where the collider is (or just import the collider as a particle using a Birth Objects operator) and bind to that particle instead.
(10-15-2020, 05:15 AM)tyFlow Wrote: Hi Apratim,
okay, now I understand,
thank you.
