Position Transfer for 2 Dynamic Object
Hi Tyson
   First of all let me thank you for your Brilliant plugin.Then I faced a problem .I want to morph from one dynamic character to another one with same topology and animation. I found Position Transfer operator and tyParticleSkin Modifier seem good for this job if I didn't make a mistake.
   I searched and tested but I can't find any solution. Can anyone help me to solve this problem or suggest a different solution?
Can you post an image or something of the effect you’re trying to achieve?
Somethings like this ?
https://youtu.be/e25wCObUmNs?t=78
Yea, Position Transfer could work for something like that. What's the issue you're running into?
(08-10-2022, 01:20 PM)tyFlow Wrote: Yea, Position Transfer could work for something like that. What's the issue you're running into?
My Problem is when I save particle position based on vertices and load in other Position Transfer. Particles never go to corresponding target vertices and stay in weird position. BTW If I have problem in adding operators in proper way ,suggest me the right one.
Thank you in advance
See attached....
.max   posTransfer.max (Size: 796 KB / Downloads: 124)
(08-12-2022, 04:54 AM)tyFlow Wrote: See attached....
thanks a million
This is a exact thing which I want Heart Smile
