objectbind reframe
Can you add a ref time to objectbind? because it causes an error when the object's surface points are too close together
Please be more specific about what error you're referring to. Provide a Max file with a reproducible example, etc.
(07-06-2024, 05:53 AM)tyFlow Wrote: Please be more specific about what error you're referring to. Provide a Max file with a reproducible example, etc.
When a flower grows from small to large, I convert it to cloth and bind the original animated object with objbind, but when the growth is done it goes wrong,If I bind the object with a frame offset, and bind it when the flower is complete, then it won't have any errors
I have attached the file below 3DSmax2024.2
.max   grow_bind.max (Size: 5.68 MB / Downloads: 190)
