UV map animation not updating in TYflow
In the Scale operator, section: texmap, Tyflow doesn't seem to be following an animated UV map.
Is that a current limitation or am not doing it correctly?
Actually it's not following the animated object as well.
Using birth voxels on a box and animating the box. Not sure what I'm doing wrong here Undecided
In what way are you animating the map?
(04-25-2019, 01:09 AM)tyFlow Wrote: In what way are you animating the map?
It's actually not just the map, it's the object as well.
Using birth voxels on a box, when I move it around in the viewport the voxels move along with it. But if I animate the box (just moving it up) the voxels don't follow.
Can you screenshot your flow?
(04-25-2019, 02:18 AM)tyFlow Wrote: Can you screenshot your flow?
Sure, I have the same issue with even the most basic setup here: bx with voxels
TYflow doesn't follow the animatied objects
Am I doing something wrong?
Thanks Tyson
Well, you're only birthing at frame zero for starters... Smile
(04-25-2019, 03:37 AM)tyFlow Wrote: Well, you're only birthing at frame zero for starters... Smile
Ah damn, I swear searched as much as I could before asking on here.  This is starting to make more sense to me now. Thanks a lot man.
