05-12-2019, 05:11 PM
I have a fairly complex setup using several birth shapes, Physx Binds, breaks, splines, collisions, etc. If I dial everything in to something that is exactly the results I want, then simply re-cache or save/load the file and preview again...the results are slightly different. This is making it very hard to get an approval from the client or to repeat a setup and expect identical results. Is this a known issue with the PhysX engine or other solvers used in TyFlow? Are there any ways to avoid this? Using the latest beta build 16022 and Max 2019. Thanks.
