animated object following flow
hey flowers!
is there a possibility to have an object animated via morphtarget and then use that keyframed object as an actor following the flow?
what's the right approach on this ?
the worms scenefiles tyson prepared do the exact thing i want to achieve but they are rigged with bones and then animated.
do i have to make a bone rig ?
cheers!
edit #2: i think i'm missing something. sorry for reediting, this is making me nuts. i have a plastic bag that i want to act like a cloth - with all the forces applied slowly floating upwards.
at the same time, i want the bag shape to be overall animated. i've done that with making it a tyactor.
tyflow doesn't seem to take the animation into account. i've attached my 'flow'
Did you enable non-skin deformations in the tyActor settings?
(07-31-2019, 05:22 AM)tyFlow Wrote: Did you enable non-skin deformations in the tyActor settings?
after i read the documentation back and forth Big Grin i actually did _ anyways still no animated movement whatsoever.
edit:
i think this is the main question:
can i turn an animated object into a cloth bind (and also put some forces on that cloth object)
And you also made a proper animation clip, which you're playing with the Actor Animation operator?
If the problem persists, please upload the scene file.
sorry for answering so late, thanks for your time Smile
i recreated that problem in the scene file you provided, the self collision cloth object with the cubes rolling down the stairs.
i animated the cube object and defined it as a tyactor, put the animation with the right keyframes in. it won't "play" the animation tho.
Still gotta upload a scene file for me to debug anything...
(08-05-2019, 01:31 AM)tyFlow Wrote: Still gotta upload a scene file for me to debug anything...
i'm not sure if there is something to debug as i'm not sure if i'm doing it right :S
but here it is
.max   tyFlow_softBodies_001_w_actor.max (Size: 620 KB / Downloads: 352)
