tyFlow v0.16066 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16066 (BETA) (/thread-1388.html) |
tyFlow v0.16066 (BETA) - tyFlow - 01-17-2020 tyFlow v0.16066 is up! http://beta.tyflow.com Additions: * Growth operator (DLA) growth bounds mode can now accept force influences * added "frame exclusions" options to Timing rollout, for specifying specific frames or frame ranges that should be excluded from operator execution * Spread operator now has seed by time option, as well as proper turbulent noise controls * added "actor rig parent" option to Set Target operator * added "preserve local offset" param to PhysX Bind deformation options, for controlling how strongly position offsets between bindings will be preserved after deformation Fixes: * fixed a regression where the Birth Objects operator would crash if you disabled "inherit geometry" * fixed a bug where the tyProperties modifier was not working on skinned mesh bones * fixed a bug where tyParticleSkin modifiers imported into a tyActor were not properly transferring custom property values * Birth Objects now supports all node types as input * fixed an issue where tyFlow was not properly rendering with the PHXFoam shader RE: tyFlow v0.16066 (BETA) - tyFlow - 01-21-2020 PhysX sleeping is no longer supported. |
