tyFlow v0.16088 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16088 (BETA) (/thread-1749.html) |
tyFlow v0.16088 (BETA) - tyFlow - 05-27-2020 tyFlow v0.16088 is out! Please read the version history for information about changes made to VRay compatibility in this version: http://beta.tyflow.com Additions: * merged VRay builds - no longer need 3.x/NEXT distinction...each build of tyFlow should now work with VRay 3.x/4.x/5.x for all versions of max from 2016-2021 * added VDB Copy Out operator, for splitting VDBs out to multiple events, SDF morphing, etc * added y-up to z-up switch in Birth VDB operator * VDB Clear operator now has options to choose which grids to clear * added Occluded Faces mode to tySelect * added density values display to VDB Display operator * Element Fracture now has seed by time option * VDB to Mesh operator now has option to toggle mesh rendering Fixes: * fixed an issue where custom bitmaps used for Display operator sprite mode would not display properly * fixed an issue where the "unify colors" rc menu option for Display operators was not copying colors with the correct gamma * improved accuracy of Occluded Elements mode in tySelect * fixed an issue where pick/add/remove/etc buttons on the VDB Modify Particles rollout were not working * fixed an issue where a tyBend applied to a spline would convert the spline to a mesh * fixed a bug where VDB meshes were not exporting to tyCaches correctly * VDB Display operator will no longer draw density points with a voxel value of 0 * fixed editor window minimum resize width when rollout count > 1 * fixed an issue where "save hit location" in the Surface Test operator wasn't working * fixed an issue where Element Fracture operator was not retaining original element count when percent < 100 * fixed a divide-by-zero issue in the Cluster Force operator |
