tyFlow v0.16010 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16010 (BETA) (/thread-208.html) |
tyFlow v0.16010 (BETA) - tyFlow - 04-07-2019 v0.16010 has some new features as well as some additions to the example scenes. Grab them here: http://beta.tyflow.com NOTE: VRay NEXT GPU is not yet compatible with tyFlow VRay instances. CPU mode should work without issue. NOTE: VRay IPR GPU is having some issues with tyFlow at the moment. As a temporary workaround, disable the "VRay Interface" in the tyFlow Interfaces rollout before rendering. * fixed matIDs not showing up properly in the viewport, for instanced particles with a display operator set to "geometry" * added occlusion testing in surface operator * copy operators with shift + drag. instance operators with shift + alt + drag * speed operator velocity/direction can be derived from particle parent * speed operator direction can be derived from the outwards direction from particle parent * spawn operator parent shape spawn offset controls added * "remove all" option for listboxes replaced with menu that includes "remove all", "remove deleted", etc * global helper functions added to script op for static Point3/Matrix3/etc math functions (Dot, Cross, etc) * retimer now supports retiming playback by speed % * rotation operator in surface align mode now supports splines...particles will be aligned to the spline tangents RE: tyFlow v0.16010 (BETA) - Heerockss - 04-07-2019 * retimer now supports retiming playback by speed % <---- Nice! |
