tyFlow v0.16100 (BETA) - Printable Version +- tyFlow Forum (https://forum.tyflow.com) +-- Forum: tyFlow Discussion (https://forum.tyflow.com/forum-1.html) +--- Forum: Latest Builds (https://forum.tyflow.com/forum-6.html) +--- Thread: tyFlow v0.16100 (BETA) (/thread-2122.html) |
tyFlow v0.16100 (BETA) - tyFlow - 12-31-2020 tyFlow v0.16100 is up! http://beta.tyflow.com Additions: * added tyBind helper object which allows you to precisely specify location of PhysX binds on input tyActor rigidbodies * Modify Bindings and Modify PhysX operators can now adjust bind break thresholds * tyCache objects will now automatically disable instancing in both viewport and render if modifiers are present on the object (previously you had to manually uncheck GPU/render instancing if modifiers were present) * added "convert input to mesh" override to tyParticleSkin Fixes: * fixed a regression where tyParticleSkin could crash if input particles did not have assigned meshes * fixed an issue where Script operators could not assign UVW values to mapping channel 0 * fixed an issue where the Particle Bind CCCS radius value was accidentally treated as a diameter value (it was resulting in binds getting half the collision radius they should be getting) * fixed a regression where tyParticleSkins imported into tyActors would not display their skinned meshes in the resulting flow * fixed an issue where max could crash when doing threaded deletions of native Mesh pointers * fixed a crash that could occur in the Modify Bindings operator if it modifies tearable cloth with aerodynamic forces * deprecated "tyActor node properties" rollout in tyActor helpers. Users should use tyProperties modifiers instead. * fixed an issue where the Speed operator noise value was not acting as an additive multiplier * fixed a regression where tyCache objects set to render as meshes would still render as instances in vray |
